04-17-2017 | #1 |
Low oil pressure??
I just fixed the vacuum leak on my 1991 ZR-1 with 68k miles. It now idles at 750 rpm but now I've noticed that once the engine warms up the oil pressure is ~30psi. This seems lower than what I've read is normal. Pressure does increase with speed. Should I worry?
Sent from my XT1080 using ZR-1 Net Registry mobile app
1991 ZR-1 #520 Arctic White/Gray |
04-17-2017 | #2 |
Re: Low oil pressure??
No
