02-17-2015 | #1 |
Drivers power window works but doesn't!!???
I'm working on my 1991 Zr1 and came across a strange issue. With the drivers side door closed the power window moves a hair but no further. If I open the door while holding the switch still nothing. Now if I left go of the switch and push it again the window goes up and down with no issues. Essentially with the door open window works fine, door closed it moves a centimeter and then nothing.
No obvious binding and motor has good speed with door open. Any ideas |
02-17-2015 | #2 |
Re: Drivers power window works but doesn't!!???
Well i went back to examine it again and it appears to be binding at the very top. Once the door opens it unbinds and works as it supposed to. Any ideas? I'm taking off the door panel shortly. Thanks
02-17-2015 | #3 |
Could be a window Alignment make sure the guides on the top of the door frame and good and not lose after you take the panel off you can see them.
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
02-17-2015 | #4 |
Could be you have a broken window guide.
We had rash of that going around a while back. http://www.zr1.net/forum/showthread....ghlight=window
02-17-2015 | #5 | |
Another possible cause is due to poor quality non-OEM weatherstrip on B and C pillar. If the weather strip is rubbery, chances are that these weatherstrip are poor quality non-OEM part resulting in grabbing the window and not allowing it to slide up or down. |
02-19-2015 | #6 |
secondchance - my car is a 1991 - I don't think they used guides yet - at least I don't see any in the door. I was able to adjust the anti-rattle pads at the top of the door frame - seems to have done the trick - looks like it was pushing the glass to hard causing it to bind - I've rolled it up and down a dozen times with the door closed and all seems good!
02-19-2015 | #7 | |
