01-26-2015 | #1 |
Thottle Cable Adjustment?
While doing our final checks yesterday before I fired up the new motor, it was discovered that my throttle plates are not opening fully when I mashed down the accelerator pedal. Is there any kind of adjustment on the cable for a 90? The later cars have an ajustment up by the ASR, I didn't see anything on mine.
Rich
01-26-2015 | #2 | |
Re: Thottle Cable Adjustment?
01-26-2015 | #3 |
Well, lets hope the car has gobs of power with the throttle only part way open. 'magine when it opens all the way!
01-26-2015 | #4 | |
Rich
01-26-2015 | #5 |
You must have stretched the cable with all that pedal mashing!
Should be able to rig something at the pedal. |
01-26-2015 | #6 |
There is on a 95. I'm pretty sure the 91 has one too. Don't know about 90 but here goes: Trace cable and see if it has a block type section. If so, there will be a hard plastic plunger or release. Depress pedal all the way then depress the plunger. I'll look in svc manual.
Ted |
01-26-2015 | #7 |
Ted I don't believe the plunger adjustment on the throttle cable came out untill ASR. None on my 91 .. 93 has it.
01-26-2015 | #8 |
Concur. No talk of adjustment in 90 svc manual. Just references no binding and seat correctly in pedal. There is however description for cruise.
Ted |
01-26-2015 | #9 |
Ted,
That's only on ZRs w ASR. 92-95. 90-91 are twin cables instead of 1.
