Old 09-20-2017   #1
Regimof
Default (ABS)/ASR service under hard acceleration
So..... Let's see about this one...
Under hard acceleration sometimes the brake warning light will come on. If you let off it goes away, however if you stay in it because some goofy Porsche wants to get Bucky, the abs and ASR service lights comes on. If you shut the car off and turn it back on they are off again.
Thoughts?
Regimof is offline   Reply With Quote
Old 09-20-2017   #2
Default Re: (ABS)/ASR service under hard acceleration
what's your brake fluid level at ?
Old 09-20-2017   #3
Regimof
Checked. Its good. Probably old, but the correct level.
Old 09-20-2017   #4
What happens when the ASR button is off? Same problem ?
Old 09-20-2017   #5
Regimof
Fun fact. Never thought to try it..... Seems I have research to do tonight.
I love research.
Old 09-24-2017   #6
Regimof
After researching...it does the exact same thing.
Old 09-24-2017   #7
Ok next I would reset the cables to make sure they are correct. Look for threads on how to do this and ask Dominic he's has some sort of the procedure he's done before... he's a mod on here and goes by the handle of xfirez51
Old 09-24-2017   #8
Regimof
Ok next I would reset the cables to make sure they are correct. Look for threads on how to do this and ask Dominic he's has some of the procedure before he's a mod on here and goes by the handle of xfirez51
Awesome. Thanks.
