01-24-2020 | #1 |
Condensation on AC lines
Today it was 46 degrees and took the Z out for some exercise. When I returned and popped the hood to connect the trickle charger, I noticed the AC lines were dripping. I know on a warm day with the AC on water will accumulate under the engine.
Never noticed this before and wondered if this was normal. Just curious from the attached photos.IMG_3817.JPG IMG_3815.JPG IMG_3816.JPG There are no other noticeable issues in the engine compartment. Sent from my iPhone using ZR-1 Net Registry
01-24-2020 | #2 |
Re: Condensation on AC lines
Normal. AC was working, but humidity in the air. If it was on auto setting of climate control, then compressor was on, even if blend door was more on the heater side.
Sent from my iPhone using Tapatalk |
01-24-2020 | #3 |
yep totally normal, cold lines from compressor being on and a big o hot engine in there
01-25-2020 | #4 |
01-26-2020 | #5 |
Man that is a relief, I had the same concerns. I went to cars and coffee and when I opened the hood lots of condensation on the AC lines. Glad to hear it is normal, thanks!
