![]() Join Date: Mar 2014
I have 61,800 miles on the 94, is there any concern using MOBIL 1 high mileage 10W-40 for the LT-5, even though it is formulated for 75000 miles and above?
Right now i have MOBIL 1 5W-30 in the engine. I know that the Amsoil AMO 10W-40 seems to be the preferred choice for our engines, but am curious about the oil in question. Thanks for any info.....
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member |
![]() Join Date: Nov 2013
best oil you can use because of the high zinc content. it provides lubrication to the cam chains and it can be bought at any walmart. it is the best and its what I use.
ed ramos #3028
EDRAM454 1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD. |
#3 | |
$15 off $75, or $10 off $50 for any purchase in the store. So I can use that to bring the cost down and I think on another thread here or CF, that there is a rebate being offered for MOBIL 1 for awhile. Also reading the label on the High Mileage, noticed that there are sealant additives in the oil to help prevent leaks, hence maybe the 75,000 mile designation. It's not like out engines say ok we are at 75,000 now, and you need sealant additives, because you are going to start to leak oil. Guess I am being my anal self and over cautious.... ![]() I know the oil debate has been beaten to death, but always enjoy other opinions as well......
![]() Join Date: May 2005
Click HERE for a good discussion of oil and the LT5.
Mobil 1 High Mileage is listed as acceptable for the LT5 engine with OE valve springs. Amsoil AMO 10-40 is recommended for the LT5 as it has the optimum zinc formulation. This is why a number of ZR-1 owners use/recommend Amsoil. The M1 High Mileage is readily available at my local wallyworld but I can also get Amsoil from a local farmer who uses it in all his diesel engines ... and his price for the Amsoil is close enough to the Mobil 1 that I'm happy using Amsoil. |
![]() ![]() ![]() Join Date: May 2007
another vote for Amsoil
![]() Join Date: Nov 2011
I worry about anything I can buy at Wal-Mart. It just seems to devalue it.
#8 | |
ed ramos #3028
#9 |
![]() Join Date: Feb 2011
I think the reason the high-mileage formulation are advertised for 75000 mi and up is because that's about when the govt mandated warranty for catalyst lifespan expires.
#10 | |
