Check out the cam spec in particular. Roller?
OWNER Tony Cardiello; Brooklyn, New York BLOCK Cast aluminum DISPLACEMENT 350 ci COMPRESSION RATIO 11.25:1 HEADS LT5 cast-aluminum (fully ported with reconfigured combustion chambers, modified valve seats, Callaway valvesprings, and titanium retainers) VALVES 1.54/1.38 CAMSHAFTS Four Callaway overhead roller (252/252-deg [primary], 272/252-deg [secondary] timing, 0.390/0.390-in lift) CAM FOLLOWERS Callaway PISTONS Callaway-spec forged aluminum (custom manufactured by JE) CRANKSHAFT Callaway-spec forged steel RODS Callaway-spec forged steel (custom manufactured by Carrillo) INTAKE MANIFOLD Ported LT5 aluminum THROTTLE BODY Ported factory twin 59mm Read more: http://www.vetteweb.com/features/vem...#ixzz2EqSRChFx
![]() Join Date: Mar 2007
Not sure they followed up on the cams use......EPA issues. There were other cams developed. No one is sure, not even the guy who made the cams, if the cams made into the cars.
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 12-12-2012 at 10:26 AM. |
#3 | |
These would have been healthy cams even bigger than Pete's although the lift is smaller. And rollers?? I'd like to see that.
![]() Join Date: Dec 2003
Dom,those are stock cams.
That duration is actual duration at .004 Advertised duration is @ .050 is .214 .229 You notice the ex & int primary are all 252/214 dur This one is Exhaust 252/252-dur primary & secondary This is the Intake 272-dur secondary/252-dur primary Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 12-12-2012 at 11:46 AM. |
