I purchased oil cooler lines from Jerry's Gaskets shortly after buying my car in March of 2018. The quality is great but they are collecting dust in my garage. The factory AN flare fittings will not budge. I've tried several times and had the car to two dealers without luck. At this point I just want direct fit OE style replacement lines. I'm tired of the headaches and tired of cleaning the leaked oil after every drive. I know there aren't and pre-made lines on the market, so I was thinking maybe a vendor who builds lines to order? I found a company called RB Royal https://www.rbroyal.com/ that looks promising. Has anyone gone this route?
![]() Join Date: Apr 2007
A few good hammer blows on a box end wrench should bust them loose. Steel fitting threads screwed into aluminum have a tendency to freeze up. Shock of hammer blows will release them.
![]() Join Date: Nov 2016
This is what I did along with the "two box" wrenches. Seemed to work just fine.
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker ![]() |
#5 | |
![]() Join Date: Jun 2005
Ah, yes...when all-else fails, get it hot!
Open flame could be risky in that area of the engine. Aluminum sucks up a lot of heat compared to iron or steel. To be safe I would remove the complete oil filter/sending unit, remove the filter, plugs, control valves and thermostat, flush remaining oil out with solvent.
To hold bolt it down to a piece of 2x4 and use a vice. Be careful not to use to much heat with cast aluminum. Sent from my iPhone using ZR-1 Net Registry
#7 | |
![]() Join Date: Dec 2003
![]() As for the inverse of this procedure a/k/a installation tightening; We have had 2 customers break the Oil Cooler Adapter by over-tightening the new fittings during installation. Teflon thread sealants (tape especially)greatly reduce friction on the threads. Add in tapered threads for the wedge effect, and large wrench size and it's a perfect storm for over-tightening especially if you think removal effort has any relativity to proper tightening. Thread sealant is required and Loctite 565 is a good product for this application.
I appreciate all of the suggestions, but they are not working. The wrench method (looped and hammer blows) is doing nothing more than starting to deform the fitting. I’m afraid that any more force is going to round the edges.
The online retailer never responded so I went to three local hydraulic shops today. None had the equipment available to rebuild the OE lines. I ended up purchasing two 12AN to 10AN adapters so I could install the Jerry’s Gasket kit without having to remove the factory fittings. Unfortunately, that did not work as the lines would need about 1 ½ inches cut from them to fit with the adaptors. My train thought is to build my own lines: factory 12AN fitting>12AN to 10AN adaptor>45degree 10AN push fitting>generic hose>90 degree 10AN pushfitting>Jerry’s Gasket oil cooler adaptor. Last edited by Black Red '90; 01-03-2020 at 08:16 PM. |
#9 | |
#10 | |
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 01-11-2020 at 04:28 PM. Reason: 2 keys with 1 finger spelling error |
