06-13-2022 | #1 |
primary timing chain
Anyone have a NOS primary timing chain they are willing to part with?
Thank you John |
06-13-2022 | #2 |
Re: primary timing chain
06-13-2022 | #3 |
I would appreciate that greatly.
Thanks Phil |
06-15-2022 | #4 |
Found some here
https://www.ebay.com/str/zuzialovesc...75.m3561.l2563
06-15-2022 | #5 |
I do not find any primary timing chains there. do you have a specific link to one?
thank for your help |
06-15-2022 | #6 |
https://www.ebay.com/itm/17518648575...4AAOSwUC1iInL7
They had left and also right
06-15-2022 | #7 |
Here is the right
https://www.ebay.com/itm/17518648574...kAAOSw~IdiInL~
06-15-2022 | #8 |
Left & Right are Secondary Timing Chains, not Primary. The Primary Chain connects crankshaft to Idler Sprocket in the center, straight above the crankshaft.
Jerrys Gaskets has NEW & USED, L&R OE Secondary Chains and also the IWIS mfg Secondary Timing Chains. We only have used Primary Chains. The Primary chain is very robust and seldom requires replacement.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 06-15-2022 at 01:30 PM. |
06-15-2022 | #9 |
Got it and thanks. This is why I am the group cook !
06-15-2022 | #10 |
Jerry,
I am very impressed with IWIS chains. I have a set of your cam chains in hand and they are very very nice. I will tell you more once I get this thing fired up.... I was telling the wife, If Jerry was not here we would all be pretty screwed when something breaks. So, Thank you for all that you do John |
