09-06-2020 | #1 |
Car running rough and Stalling
Thoughts on the data below I am thinking a map or TPS issue? Idles ok and then falls apart and almost stalls when you accelerate Image1599440706.215497.jpgImage1599440726.696596.jpg
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 09-20-2020 at 10:42 AM. |
09-06-2020 | #2 |
Re: Car running rough and Stalling
Hmm, bad MAP should throw a code.. TPS with key on engine not running you should be able to exercise the TPS and see the voltage.
How old is the gas?
09-06-2020 | #3 |
I commented on FB that the MAT sensor reading was low unless it was relocated.
09-06-2020 | #4 |
-New Gas
-New fuel Pumps -New Filter -Pumps and pressure test good -Spark seems strong it will arc when pulled -idle is fine -Once under load it almost dies -when you let off and give it a second it recovers and you can drive slowly
09-07-2020 | #5 |
Sounds like my problem a few days after I installed new fuel pumps. One of the hose clamps came loose and under load would pull away from the assembly and starve the engine of fuel. Replaced with stainless clamps and problem solved.
09-07-2020 | #6 |
Im not seeing drops in Fuel Pressure but will put this on my list, thanks
09-07-2020 | #7 |
Have u checked injectors?
09-07-2020 | #8 |
09-07-2020 | #9 |
09-07-2020 | #10 |
-New MAP sensor and hardline hose; little to no change
-Seems like its maybe not getting enough fuel or timing
