Old 02-11-2017   #1
garyhugo
garyhugo's Avatar
Default Swapping pulleys on alternators
OK, thought this would be easy. Put the alternator fan in a vice just snug enough to hold and had my father hold it. 15/16 socket on breaker bar and with great force the nut and shaft appear to rotate together. Not loosening.Now what?
Gary
90-1572
garyhugo is offline   Reply With Quote
Old 02-11-2017   #2
RussMcB
Default Re: Swapping pulleys on alternators
Breakaway oil and an air impact wrench?
Old 02-11-2017   #3
secondchance
Question Re: Swapping pulleys on alternators
You need an impact gun - air or electric.
Take it to a mechanic near you. Slip him a $5 and ask to borrow an impact.
Old 02-11-2017   #4
Roadster
Roadster's Avatar
The easiest way to accomplish this go to a service establishment where they have an air wrench. Tire place, Pep Boys, etc. and have them change out the pulleys for you. Will cost you a few dollars....
I ended up buying an electric corded impact wrench from Lowes, which did just fine. But I also have more use for the purchase.
You still need to prevent the fan from turning when loosening or to tighten the nut. I used a small crow bar for that purpose, just to wedge between the fan blades. Worked for me...
Or you can follow Dynomite's suggestion in post #84 & 85 in the link below with the alternator installed on the vehicle, and modifying the tools suggested....
http://www.zr1.net/forum/showthread.php?t=27427&page=9
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-11-2017   #5
garyhugo
garyhugo's Avatar
OK, just realized the inside of the shaft is an allen.Can't use a socket,have to use a 15/16 offset box wrench and hold the shaft still with the allen. Of course I have all off sets to 7/8 so off to NAPA and hopefully they have one.
Gary
90-1572
Old 02-11-2017   #6
garyhugo
garyhugo's Avatar
Pulleys swapped and alternator in. Soon as the battery is charged up I'll get my final grade.
Gary
90-1572
Old 02-11-2017   #7
Roadster
Roadster's Avatar
And how did you get the pulleys swapped? I'm sure you"ll get an A+++
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-11-2017   #8
garyhugo
garyhugo's Avatar
Using a 15/16 offset box wrench on the nut and an allen in the shaft I was able to loosen the nut.The new alternator nut came off using a socket and breaker bar.Just swapped the spacer, pulley and washer from my old alternator to the new alternator. Started up and everything seems to be working correctly.Pulley and belt are spinning tru and the alternator fan is spinning tru(not hitting the alternator).I'll take it out for some real world testing tomorrow morning.
Gary
90-1572
Old 02-11-2017   #9
Roadster
Roadster's Avatar
Good job, I'll be next!!!
Sent from my SM-G935P using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-11-2017   #10
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Most towns have old-time "generator/alternator rebuild shops".
If your town does not; send me a pm and I can get you the particulars of a shop that we have used for years that happily and competently rebuilds our units when we are striving for originality.
They don't wear smocks or white lab coats, and they have no "technicians", but they sure restore them to as new performance!
Marty
DRM500RUBYZR-1 is online now   Reply With Quote
