03-28-2013 | #1 |
Headlights clicking
Turned on the headlights and the right headlight motor kept clicking for about 4 seconds after full rotation and then stopped. Same clicking noise when I closed the lights.
Should I just buy the 3 bushings or go for the full kit, bushings and gear? Get the more expensive bronze gear or plastic? Thanks for your suggestions
03-28-2013 | #2 | |
Re: Headlights clicking
Just get bushings for now. 90% - bushing will cure it. |
03-28-2013 | #3 |
I just bought a new nylon gear for my '90 right side.
Before it got in, I opened it up, and found a crack in the gear. I expected to find crumbled Delrins - the 3 little guys INSIDE the nylon gear. I cleaned it, and turned the nylon gear 180, re-installed, and waited for the new one. It works fine now. Some GM electric motors do NOT rotate the nylon gear more than 180 - S-vehicle A/C temp control module, for one. And our headlight unit doesn't rotate more than 180 either, so I'm guessing that's why mine is working properly now, with the cracked gear re-installed.
03-28-2013 | #4 |
This is what I found in a '94 that I did the headlight sticky for:
and how to get the armature back inside the brushes!!! I have the rest of the snappics and sequence for breakdown if you need...
03-28-2013 | #5 |
Thanks guys, will get the 3 bushings and hope I am in the 90% group!
03-28-2013 | #6 |
Yep as the others have stated its the bushings
