11-29-2014 | #1 |
Wanted: 1991 ZR-1 motorized antenna.
Hi,
Does anyone know of a source or have an OEM motorized antenna for a 1991 ZR1? None of the big catalogs carry one specific to ZR-1s. Mine has a broken nylon drive cable that winds up on the internal drive motor spool. If I listen to anything it's CDs, but I want to keep things original. Thanks for any leads! Regards, John |
11-29-2014 | #2 |
Re: Wanted: 1991 ZR-1 motorized antenna.
Bit pricey (use to be around $150) but below is an OEM antenna.
http://www.ebay.com/itm/NOS-DISCONTI...155940&vxp=mtr Another option, if you can hear electric motor running, just replace the mast. http://www.ebay.com/itm/CORVETTE-Pow...fe5595&vxp=mtr |
11-29-2014 | #3 |
Thanks Secondchance!
I scoured ebay too. Must not have used the right magic words. $350 for a new one is pretty stiff for something I don't really "need". Option 2 is perfect! I had mine apart and the nylon cable is broken, the motor works fine. $30 and FREE shipping. Tough to beat that. I really appreciate your help. Thank you. John |
12-01-2014 | #4 |
Hello Yun,
Do all years of ZR1's use the same electric antenns? Nelson
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
12-01-2014 | #5 |
12-01-2014 | #6 |
I have the whole assembly from a 94, it is broken. Its the same problem you have,
But if you run across the rubber grommet for a ZR-1 the antenna goes through in the fender; would you let me know. Thanks, Ryan
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
12-01-2014 | #7 | |
Difference is early cars have external relay for the antenna and later cars have relays internally. I still owe you antenna repair. You didn't show during the last WMD. |
