01-14-2020 | #1 |
Dimmer Switch Doesn’t
I can’t switch from lo beam to hi beam on my Z. The switch itself works as I have taken the panel out and dropped the wheel down. It’s the rod itself that moves around and jams up. I’ve looked at other sites and the best that I can come up with is that the steering wheel itself has to come out.
Anyone ever worked on this problem? Roy
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 ZR-1 Net Registry Board Secretary |
01-15-2020 | #2 |
Re: Dimmer Switch Doesn’t
Does it work at differing tilt selections, or does it occur at only one tilt position?
Marty |
01-15-2020 | #3 | |
I have a 100,000 mile Z that works great! This car has only 48,000. ??? Roy
02-01-2020 | #4 |
Roy,
Sorry, I lost track of your issue. If you have not resolved it, you might want to try this. Rarely, almost never do the rods bend due to a problem with the rod. Most always a misadjusted switch down at the base of the column causing it to bind. It is mounted below the ignition switch, and it is adjustable. If it is not binding there, it would be at the top, but let's hope it is down at the switch. Keep us posted. Marty |
02-03-2020 | #5 |
I was busy working so I didn’t see this. The dimmer switch does work; it’s the rod that is the problem. So if I can adjust the bottom position, I might be able to get it to work. I will give it a try this weekend.
Roy
03-27-2020 | #6 |
I haven't got back the dimmer switch until now. Too busy working. Now that I have time, I'm back on it. The big question is do I have to pull the steering wheel to fix the actuator? I'm going to try to adjust the bottom of the rod to make it work. If that doesn't work, what then? Does anybody have pictures of the actuator and how it fits in the stalk? Thanks.
Roy
03-28-2020 | #7 | |
04-06-2020 | #8 |
Thank you. I haven't been able to work on it because I pulled a muscle in my back. Finally got back to working on the problem. I dropped the steering wheel down so I could look better at the switch. Apparently, I have to remove another panel to better access the switch. I'll keep working on it.
Roy
04-07-2020 | #9 |
I dropped the steering wheel down and was able to get to the dimmer switch wire. By messing with it, I was able to get the stalk to work but it only works for a little bit. It seems to feel like it was sliding off whatever it is working. I do have a quesion for you guys. How do you get this piece off the column?
04-07-2020 | #10 |
Sent you a PM. you need to get further back and look inwards toward the wheel and see if you can push the pivot back into place assuming it is not broken.
