12-07-2014 | #1 |
AC low blow
Have any of you had a low blow system for the air with high setting? No codes pulled yet.
With it on the setting of 10, the air comes out as if it was maybe a 3 or 4 - not loud and the air seems very low - looking for it to be powerful at 10. My other corvette and even truck, when the high setting is on you know it, it's very loud with lots of air blowing out. Blower fan bad or not pulling the correct rpm's? Crap in the coils limiting air flow - hope not cause that seems it would be major pain to get too. I really hope it's not a programmer either. Thanks |
12-07-2014 | #2 |
Re: AC low blow
Are you sure it is not just the weak A/C system in our cars?
I noticed my Manual AC on max fan is maybe 1/2 of that of a newer car..
12-08-2014 | #3 | |
Re: AC low blow
At least I don't think it's the AC system in these cars - 10 - does not feel strong at all. I owned a 91 ZR-1 for like 13 years (traded it in about 4 years ago or so), and from what I remember the air came out much stronger in my old ZR-1 vs this one.thanks |
12-08-2014 | #4 | |
Re: AC low blow
12-08-2014 | #5 |
Re: AC low blow
Bang the outside of the housing to change the speed?
12-08-2014 | #6 |
Re: AC low blow
Yep I tapped mine with a rubber mallet and the pitch changed lol. Replaced the unit and never looked back
12-08-2014 | #7 |
Re: AC low blow
AH, makes sense now.. Like banging on a starter to see if it is bad..
12-08-2014 | #8 |
Re: AC low blow
Yep there was some binding in the motor so it was basically shot. Should be no surprise really as these old girls are in their mid 20s. Age and use are both a factor. It was time for a fresh blower motor
