12-24-2015 | #1 |
Interesting ignition module with a LT-5 I bought
This came with the engine I Just purchased
No crank trigger however https://electromotive.com/wp-content...15/05/hpv1.pdf
12-24-2015 | #2 |
Re: Interesting ignition module with a LT-5 I bought
I thought Electro-Motive made Diesel train engines.... --Bob
12-24-2015 | #3 |
12-24-2015 | #4 |
Electro-Motive, the one-time locomotive manufacuring division of GM, is now owned by Caterpillar.
Electromotive is a long time maker of aftermarket street-performance and racing ignition systems. Usually, people replace OE ignition systems with Electromotive hardware when modifing an engine for racing.
12-25-2015 | #5 |
Fastlanes ZR-1 ran this system
The engine management system is Electromotive all controlled by a laptop
12-25-2015 | #6 |
Lee,
Did this system tie into the stock ECM? If it does, I'd like to see the wiring.
12-26-2015 | #7 |
No idea....came with but no trigger, etc
12-27-2015 | #8 |
12-27-2015 | #9 |
The Electromotive HPV-1 system uses 4 coils to fire the plugs. Each coil fires 2 cylinders at a time. The module has 4 set points. The first is for base or initial timing. The second is for advance above 3000 RPM. The third is for a slight advance or retard above 8000 RPM and the 4th is a rev limiter.
12-30-2015 | #10 |
So does this system fire the coils whenever the piston approaching TDC regardless if it's on the compression or exhaust stroke aka "wasted spark" ignition?
peace Paul ZR-1 Net Registry Member #1494 |
