07-21-2013 | #1 |
A Pilar Gauges
I am looking a putting a couple of gauges on my A pillar. I know that I want a fuel preasure gauge. My question is what kind to get, and where does it get its information (sending unit)? I would also like to get an air/fuel gauge. Same question. Where does it get its information. I like looking and your instalations!
Thanks Chris
91 ZR-1 Red on Red #922 |
07-22-2013 | #2 |
Re: A Pilar Gauges
Chris,
My Pillar mounted fuel gage gets an electrical signal from a sender that's attached via the fuel rail. I have a SS Braided line attached the end of the Fuel Rail and it runs back behind the engine where the sender is. From there it runs to the pillar. I don't have an AFR however you'll need a WB O2. There are kits out there that will have it all... My car's at the hangar so I can't run out and see the gage type. Cheers,
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
07-22-2013 | #3 | |
Re: A Pilar Gauges
Some ideas http://www.zr1.net/forum/showthread....ghlight=pillar
