Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Cleaning and Waxing
Old 10-28-2008   #1
Jason@Adams
Default All new kit from Adam's!
http://www.adamspolishes.com/p-354-a...ngine-kit.aspx
Available for a limited time only! Adam's Trim Package and Engine Kit will help restore your faded, drying, and cracking vehicle molding and trim to new! Ready to tackle your engine bay? Complete with our All Purpose Cleaner, V.R.T. and In & Out Spray this kit has all the right tools to help your molding look as good as your paint and glass!
Use our All Purpose Cleaner to clean your engine bay, weatherstripping or rubber trim and our SPF 35 UV protecting V.R.T. to restore sun bleached and faded color. Watch your black trim look brand new! For harder to reach areas the In & Out Spray is the easiest remedy you could use. Safe on all components, spray what you can't reach! Simply apply and watch the black and shine return! Any over spray is easily removed with our Detail Spray or Glass Cleaner!
Because our V.R.T. is water based you won't find it later adding to fading or cracking from the sun. Petroleum based products actually displace natural moisture in rubber, plastic and vinyl which leads to faster material break down. Use V.R.T. to prevent this!
Old 10-28-2008   #2
Default Re: All new kit from Adam's!
nice...
I remember when the In and Out spray was being remade... Gotta love that product!!!!!
Spray and DONE! Been using In & Out spray and VRT for almost 3 years... Wouldn't consider using anything else!
Class products and a discount.
thanks!
