Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 06-12-2011   #1
z proud
z proud's Avatar
Default QB93Z or Rex Ruby
Jim Or John,
Did one or both of you mount a garage door opener to the the side of the door?
I dont have the jack shaft type of garage door, I have the twin springs type of door. I am looking at adding a 4 post lift in a one car garage and wanted to add the opener to the side of the door. Already rasied the door up to clear a car on the top of the lift.
Do you have any photos or tips?
Thanks Bill
z proud is offline   Reply With Quote
Old 06-13-2011   #2
QB93Z
QB93Z's Avatar
Default Re: QB93Z or Rex Ruby
Hi Bill,
Yes, I installed a "jack shaft" garage door opener after I installed the four post lift in my garage.
I installed a LiftMaster opener.
I highly recommend this type of opener. Normal residential door openers have a L-bracket to attach to the door. The bracket extends several inches below the door when the door is opened and can contact the top of a car that is on the lift. I speak from experience.
Here are some pics:
Here you can see the bracket on the right-hand door. On the left-hand door, the "extra" door panel has been removed and the bracket is gone:
Here is a picture of the LiftMaster door opener installed:
I installed the LiftMaster opener by myself. It is a straight forward installation.
If you would like to come see the opener, we will be having a Westminster Maintenance Day on Sunday, 19 June.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 06-13-2011   #3
z proud
z proud's Avatar
Jim,
Thanks, I should drive down to do my oil change, my door does not have a jack shaft, so I am left if I want an opener to do it from the side of the door.
Old 06-13-2011   #4
Jagdpanzer
Jagdpanzer's Avatar
I used the same jack shaft opener as Jim. Also had to convert from twin coil springs over to jack shaft type lift arrangement.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-13-2011   #5
Jagdpanzer
Jagdpanzer's Avatar
Contact Mike at Pro Door Supply and he can fix you up with everything you need for jack shaft conversion
Michael Baumgartner
ProDoorSupply.com
1-800-783-3904
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-15-2011   #6
Rex Ruby
Sorry for the delayed response but it looks like you got your answer!
I didn't use the side mount anyways!
John Porter
'93 Ruby Coupe ZF6 - Muffler eliminators, Blink Blink kit and Polished ZR1 Wheels
* PA Plate: OBSSSN
'06 LeMans Blue C6 Coupe - Corsa exhaust
* PA Plate: OBSSSV
ZR1 Net Registry Founding Member #153
40th Anniversary Registry Member
NCM Family Membership #8116
Corvette Forum NE Events Coordinator
Delco Cruisers Board of Directors
SAVE THE WAVE!
Rex Ruby is offline   Reply With Quote
