10-25-2019 | #1 |
Intake & IJ Porting @ Home
I know there are a bunch of you who do this professionally....I dont know the costs of having this done, but I imagine is pricey. So, is it realistic to think a guy, with proper tools, could do this on his own at home?
I've done some porting on a couple sets of iron heads back in the day, pocket porting and bowl blending... but never fooled with aluminum. So do it at home or pony up and send it to the pros?
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
10-25-2019 | #2 |
Re: Intake & IJ Porting @ Home
I think if ur talking top end, then yeah u can do that but expect to fix some holes. Ask me how I know.
Cylinder heads I would send to someone like Marc or Pete.
10-25-2019 | #3 |
I did ALL the porting on my LT5. And, after several experiences with cast iron heads and intakes on SBCs (decades ago!), aluminum is a breeze in comparison!
With proper tools and a professional welder, one capable of doing aluminum (especially intake runners, etc, and some specs, it can be a DIY project for the right person. PM me. Headporting002Large.jpg IH7Large.jpg LT5headportingsafetydimensions.jpg
10-25-2019 | #4 |
Yes, you can do it yourself. Be prepared for lots of time as it's best to go slow until you get the profile down. Suggest a good flex shaft die grinder (Otto Frei). Makes the work much more enjoyable.[ATTACH]
Suggest you send heads to Pete or Marc as Dominic indicated. I port matched mine (primary only), which is pretty straight forward, but full porting of the heads needs some experience. Sent from my SM-G950U using ZR-1 Net Registry mobile app Last edited by jss06c6; 10-25-2019 at 09:29 PM. |
10-25-2019 | #5 |
10-25-2019 | #6 |
No heads... just intake and IJ housings... is it worth doing just those? And why will I need a professional welder??? And what holes will I need to fix? Sounds already like I better pay a pro .....
10-25-2019 | #7 |
Plenum & injector housings with 4.10s. Quite a riot. 412 rwhp.
Talk to Corey Henderson. IMG_1835.JPG Ted |
10-25-2019 | #8 |
Top end porting is the “gateway drug” for ZR-1 owners. It shows u how throttled this motor was.
10-26-2019 | #9 | |
THAT said, you can realize the lion's share of the HP (400 rwhp) benefit of porting by doing the top end only and port matching the heads (see my photo - above post). And, if you're careful to not veer from the centerline of the casting, you won't need to have that welder guy "on retainer". Some snap and ball gauges, select carbide burrs, a quality die grinder (I prefer the Snap On pneumatic for best control, but Makita makes a constant speed electric that many prefer), a steel straight-edge...and with some techniques you will be fine: nice winter project if you don't get in a hurry. Then, to top it off, you'll need a dyno tune for best reaults OR Marc can fix you up with a calibration that will "plug and play & yeild almost 100% of a good dyno session, depending on your exhaust config.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 10-26-2019 at 05:19 AM. |
10-26-2019 | #10 |
I tried “hard enough” at least twice. Thx to Al, I didn’t have a massive vacuum leak.
