11-08-2017 | #1 |
Drilling a Fidanza
So I’m about to drill the pressure plate mounting screw holes deeper and tap for the longer bolts. Is there anything special about this process I need to know before I start?
H
11-08-2017 | #2 |
Re: Drilling a Fidanza
Be sure the drill bit you use does not cut back the existing threads and use a depth stop so all are the bore depths are uniform. Make first pass with a regular 3/8-16 starting tap then finish with a bottoming tap. Use aluminum thread cutting oil.
11-08-2017 | #3 |
You may also have to slightly countersink the bore entry with a 3/8” drill bit or end mill cutter to allow the bolt shank to seat deeper.
11-08-2017 | #4 |
11-08-2017 | #5 |
My Fidanza was drilled tap size, all the way through from Fidanza. All I had to do was run the tap through.
11-08-2017 | #6 | |
Good stuff, guys. Thanks H
11-08-2017 | #7 |
Yes, drill holes went all the way through the flywheel. It was only tapped deep enough for the standard bolts. All I has to do was start the tap into the existing threads and thread them deeper. My Fidanza was purchased in 2003. Looks like I got lucky....hope you are too.
11-09-2017 | #8 | |
H
11-09-2017 | #9 |
Is there not a specialty bolt available that might make life wonderful? What is the actual depth of the holes?
11-09-2017 | #10 | |
H
