Old 11-03-2018   #1
ZWILD1
ZWILD1's Avatar
Default 02 Sensor and spark plug?
My 91 had both 02 sensors reading rich. I talked with Marc Haibeck and he said I could replace the sensors if it bothered me. But I didn't ask him what brand sensors and plugs he used. I figured I would ask you guys which brands you preferred and are running.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
Old 11-03-2018   #2
Flyman 27
Flyman 27's Avatar
Default Re: 02 Sensor and spark plug?
The ones I chose were Bosch. They work well & have not had any issues.
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 11-03-2018   #3
I use the AC Delcos. The Bosch O2s drop signal randomly. Don’t trust them. The ACs are solid.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-03-2018   #4
Replacing the right side,I think it’s the right side,is a total nightmare,do plenty of research before you dig in.
Old 11-03-2018   #5
32valvZ
32valvZ's Avatar
Rock Auto Pt # 21003 Working great in my 90
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 11-03-2018   #6
ZWILD1
ZWILD1's Avatar
Sounds good I think I will probably go with the AC's. What plugs are you guys running? So many to choose from.
Old 11-03-2018   #7
Vette73
X fire, you have the AC delco part number?
Where you buy from?
Vette73 is offline   Reply With Quote
Old 11-04-2018   #8
Dominic is spot-on RE the 'dropping out' intermittently. Drove me NUTS until I acquired a scanner that would capture data during a particular event.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 11-04-2018   #9
Where you buy from?
Got them from Rock Auto. Don’t have part # but just go down thru the catalog for LT5. Easy to find.
Also, I just installed a set of Autolite 3924 plugs gapped at .044”. These are “projected nose” plugs. The motor runs much smoother than w the NGKs.
Old 11-04-2018   #10
Pete put me onto the (copper) AC Delco 41-602s. They're not exotic, but because of the ease of access on the LT5, there's no need to pay for plugs made of everlasting "rare earth" material. At about $2.00 or so a plug, you can afford to replace them long before they start to show signs of wear (rounded electrode edges, gaps increasing, i.e., the usual burning up indicators.
These plugs I pulled after one season (or was it two?). Practically new condition, and the motor (stock cams) idle purrs like a kitten.
File Type: jpg AC Delco 41-602s with aprox 2800 miles.jpg (245.8 KB, 16 views)
90 #1202
Sans secondaries
