Old 03-03-2021   #1
Wigert
Default Goodridge braided brake lines long
Hello all
I was wondering if any of you have installed the Goodridge braided stainless steel brake lines? I just bought them and it seems that they are noticeable longer than the original. 2 are also longer than the other two. I do not see any issue in the rear (which is were I installed the shortest ones) but in the front the orientation of the banjo fitting might be more critical to avoid interference with the wheel and the wheel speed sensor cable.
Could someone show me a picture of an install? It would be much appreciated!
Regards
Christoffer
Sent from my EVR-L29 using ZR-1 Net Registry mobile app
Wigert is offline   Reply With Quote
Old 03-04-2021   #2
Wigert
Default Re: Goodridge braided brake lines long
Anyone? How about DRMs brake lines? How do they compare to the original in length?
