08-25-2012 | #1 |
Stock rearend to 4.10
What needs to be changed to switch from stock differential to 4.10? just the ring and pinion, or does the housing need to be changed also? Where is source for Dana 44 parts? Also understand Viper ring and pinion will work. Thanks
08-25-2012 | #2 |
Re: Stock rearend to 4.10
one thing that will be changed more often is your rear tires
