Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Cleaning and Waxing
Old 07-15-2009   #1
Jeffvette
Default Some shots of Adams in stages
This is on the race car, paint is ok, as it is a race car and meets the 50/50 rule. I figured I would play around with the black paint and see what I could do.
Step 1, the start.
Started with Adams Clay bar and then went to the Swirl and Haze remover to remove the good majority of the scuffs scratches and debris. After two passes the paint looked greatly improved. I could have just stopped there and been done.
Step 2 Not bad
Went onto using the fine machine polish and once again used two passes to make sure everything was covered and evenly done as I could. Looking great now!
Step 3 Almost there
Applied the machine wax to seal everything that has been done. Just used one coat making sure to cover everything and overlap going side to side and up and down. Looks awesome!
Step 4 Done
Finished up with Adams Detail Spray to make sure all the wax has been removed and the spray makes for a little more glossy appearance. Car looks great compared from the start.
Old 07-15-2009   #2
Dylan@Adams
Dylan@Adams's Avatar
Default Re: Some shots of Adams in stages
WOW!! Nice results and even nicer car!! Great work on the correction.
Dylan@Adams is offline   Reply With Quote
