01-18-2015 | #1 |
Starter Relay Connector
Has anyone noticed a difference in ZR-1 starter rely connectors? I picked up a low mileage used starter (pic on the right) a few months ago but found it has a different connector that my stock starter (pic on the left). Am I dealing with a cheap rebuild?
Rich
01-18-2015 | #2 |
Re: Starter Relay Connector
Just looked at my 90' and 91'.....the Starter Solenoid Connector is like the one you have on the Left with the Hot Wire in the center.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-19-2015 at 12:27 AM. |
