01-15-2021 | #1 |
WTB: 3" exhaust system
Does anyone have any 3" inch exhaust system they are willing to part with? Do not need mufflers, pretty much any shape.
Have a few ideas I want to try...... thanks John |
02-17-2021 | #2 | |
Re: WTB: 3" exhaust system
-=MIke Last edited by bowtiguy; 02-17-2021 at 05:32 PM. Reason: wrong O.D. |
02-17-2021 | #3 |
02-17-2021 | #4 |
02-18-2021 | #5 |
Borla was avail in 2.5 and the 2.75 Challenge system
Corsa is 2.5 Stainless works, Desert Development and B&B are 3" Magnaflow is also 3" but you need the LT1/4 exhaust then get the headpipes fitted for our cars
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
02-18-2021 | #6 |
Yes I am aware.
I have a very nice 2.5 inch corsa and will be needing a 3 inch B&B. I would be willing to trade my corsa as well, it is in very good shape and has had the H pipe widened up internally to the full 2.5 inches. sounds deeper and has more power than stock. John |
02-18-2021 | #7 |
Sounds good John!! was not sure if you knew which systems were 3", helps everyone
what is requiring the need to go to the 3" system, if you don't mind me asking
02-18-2021 | #8 |
A 402 with stage III cams.....
ported heads, big valves, ported housings and siamised plenum should get the cams in in a week or so, can't wait. I am sure I will be beat up by a million little things as it starts to go together... |
02-18-2021 | #9 |
03-02-2021 | #10 |
still looking for a 3 inch system, B & B is preferred.....
will be selling a Corsa once the 3 inch is installed thanks John |
