![]() Join Date: Jan 2004
So I'm thinking about installing an in-dash fuel pressure gauge. Has anyone ever drilled and tapped the fuel rail for a sender? I'm thinking there's room for a sender on the drivers side at the rear of the rail but I'm wondering if there's enough meat to drill and tap at that location.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
![]() Join Date: Feb 2012
Why not just hook it up to the Schrader valve?
Well I was thinking it would be nice to still have the option of hooking up a test gauge to the schader valve under some circumstances. Plus a sender at the Schrader valve would be quite visible.
![]() ![]() ![]() Join Date: May 2007
Robert I understand what your doing but are you planning on boosting the car?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-10-2017 at 09:34 AM. |
![]() Join Date: Nov 2011
Might want to talk to Todd, he's building a custom fuel rail.
![]() Join Date: Oct 2004
![]() Join Date: Jan 2015
That's what I did. IIRC, it was easy to find an adapter. I think my FP gauge's sender needed 1/8" NPT. My hunch is you could find a tee adaptor combo that would allow you to keep the Schrader port.
But, maybe retaining the Schrader port isn't needed if you have a fulltime FP gauge. |
Yep lol. Thanks
#9 |
![]() Join Date: Dec 2003
It may be better to weld an AN-2 fitting into the rail where you want it, rather than attempting a tapped hole. I would be concerned about a screw-in pipe thread fitting leaking, especially if you don't have full length engagement.
#10 |
Perhaps a tee is not a bad option, I just had the rails powder coated so welding is off the table now.
