Old 10-22-2010   #1
Blue Flame Restorations
Default Regular 89 Vette Hood Same as ZR1 Hood?
Will a regualr 89 NON ZR1 Corvette hood work on a ZR1 or do I need to buy a 90-96 Corvette hood??
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-22-2010   #2
Default Re: Regular 89 Vette Hood Same as ZR1 Hood?
Worried about the radiator and LT5 fitting properly.
Old 10-22-2010   #3
Kevin
Kevin's Avatar
the hood on the zr-1 is the same as the standard vette
Old 10-22-2010   #4
From what years? I know the 90-06 hoods are all the same but will 89 work with the ZR1 radiator configuration and LT5?
Thanks
Old 10-22-2010   #5
cvette
Technically 85-96 hoods are the same. The 84 had the plumbing underneath for the Crossfire injection. However the hood prop is not the same on the 85-86 cars so if you want everything to work perfectly in the swap you want a hood from an 87-96 model.
Charlie
cvette is offline   Reply With Quote
Old 10-22-2010   #6
Thanks
I was worried about the framework under the skin being somewhat different for the radiator assembly and LT5.
Old 10-22-2010   #7
vettebrett
Well there goes the 90 I am guessing??
'89 BLK/BLK
[B][URL="http://www.corvettechallengeregistry.com"]Corvette Challenge Registry[/URL][/B]
[B]Morrison Race Car Registry[/B]
[IMG]http://i39.photobucket.com/albums/e191/brettrichmond/C1.jpg[/IMG]
[IMG]http://i39.photobucket.com/albums/e191/brettrichmond/brettvette12.jpg[/IMG]
vettebrett is offline   Reply With Quote
Old 10-22-2010   #8
I already have an extra 90 hood but it has had a repair and I want one with no major damage ever.
Old 10-22-2010   #9
Tyler Townsley
Charlie
Not exactly true. In 90 the radiator position changed. This change was on the 88 and 89 ZR-1s so those are different than the stock hood. I think this hood was used on stock 89s as the stock of out style hoods ran out.
Tyler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
