03-02-2013 | #1 |
Mobil 1 High Mileage
Decided to go with Mobil 1 High Mileage mostly due to easy availability.
Viscosity questions now. My 91 came (I think) with 10w30. In 92 or so the factory changed to Mobil 1 5w30. M Haibeck suggests Amsoil in 10w40. Mobil 1 HM comes in all three of these (and other) viscosities. I live in North Florida so not too cold normally. Should I go with 5w30, 10w30 or 10w40? Thanks |
03-02-2013 | #2 |
Re: Mobil 1 High Mileage
I don't take any recommendation from Marc Haibeck lightly. His recommendations are always backed up with considerable research and experience - with the ZR-1 and the LT5 in particular! Marc recommends AMO 10w-40 (with the levels of ZDDP present in the oils originally used in the LT5 at the time of its introduction, by the way).
Just sayin... P.
03-02-2013 | #3 | |
03-02-2013 | #4 | |
High Mileage engines loose tolerances (use heavier oil). Hot climates (hotter engines) thin oil (use heavier oil). Cold climates (colder engines) thicken oil (use lighter oil). Often starting colder engines (lighter oil). Running engines for long hauls once started (use heavier oils). Newer synthetic oils do not loose viscosity with use (use lighter oils). In Fl or CA coastal (use heavier oils). In SD winter ....definitley (use thinner oils). Frequent oil changes (use thinner oils). Infrequent oil changes (use heavier oils).
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-02-2013 at 12:07 PM. |
03-02-2013 | #5 |
i think my civic call for 5w20 or something like that. It's basically water
03-02-2013 | #6 | |
03-02-2013 | #7 |
I use mobil 1 synthetic extended performance 5w-30
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
03-03-2013 | #8 | |
local NAPA guy (he owns the store) is an Amsoil dealer. He could not find Amsoil AMO in his computer. I drove to Walmart and they had Mobil 1 HM in no less than 5 different viscosities. I bought the 10w40 because Marc recommended that weight for the Amsoil. I just wondered if that or some other weight is best. Thanks |
03-03-2013 | #9 | |
Thanks for your time |
03-03-2013 | #10 |
When SGC did my engine work Aaron recommended Mobil 1 15-50 because of the high ZDP content. Plus in NW Fl it doesn't get that cold and it is available at nearly all auto parts stores.
