11-21-2007 | #1 |
water hoses are they still avail?
guess its time to replace the hoses on my car (the big one going to the water pump with the woven cover is leaking ) can they be got anywhere? or are they nla?
11-21-2007 | #2 |
Re: water hoses are they still avail?
There are probably some left in the inventory, but they are all as old as your car.
Samco hoses are the way to go. Do a search here in the forum on the group purchase, all the info will be there.
11-21-2007 | #3 |
hope I can find one to get by the car is my dd
11-21-2007 | #4 |
Net registry carries the samco's. http://www.zr1netregistry.com/ZR1registrystore/
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT] [FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT] |
11-21-2007 | #5 |
what is the id of that hose . i have got to try to temp fix it to get to thanx giving . thought i could put a piece of tubing in it and clamp it . also how the heck do you get that hose off of the water pump . you know the big one that goes from the water pump to the thermastate housing .
11-22-2007 | #6 |
well i get to go to turkey thanx to a creative napa guy. h found a hose out of the back room that after he cut alittle on worked . i will post the hose number when i get back . 22bucks for a lower hose way cool
11-22-2007 | #7 |
Man, my hat's off to ya Brad!
I was doing the samco kit and when I got to that one.....well it's gonna get done this winter! ............that is if I can stop driving it long enough to get some stuff done....and I even have the clamp removal tool & I still gave up after eyeing up that hose. Man it's tight working on that one. Tom
11-22-2007 | #8 |
no kidden. we yook out thf dryer the belt pulley and it was still tough. getting the old hose off was fun. stuck ciity
11-22-2007 | #9 |
I cut about an inch cut perpendicular to the ends. Then you can get a screwdriver in there to pry the hose off the fitting. The rubber pretty much fuses to the metal. Of course you can't do that if you were planning on reusing the hose. Removing the belt and tensioner helps create some access room to get to it.
11-23-2007 | #10 |
the hose has worked great so far . here is the number of the hose and the amnt taken off for it to work. the hose is napa number 7927 you take 11 in measured along the outside of the hose from the end that has the part number . make shure you transfer the spring in the old hose. the cost from napa is 21 for the hose sure beats the 84 is was quoted from the dealer.
