02-28-2021 | #1 |
Leaky Steering rack. Tips on removing?
Tearing into my 1994 Z and I have a leaky/greasy steering rack.
Anyone have a write up on how to get it out of there? LOL Any tips would be appreciated.
1994 #353 "Bluey" |
02-28-2021 | #2 |
Re: Leaky Steering rack. Tips on removing?
Check Dynomite's sticky "Solutions" at the top of this section. --Bob
02-28-2021 | #3 | |
STEERING Power Steering Pump Repair Kit Replacing Power Steering Pump TIPS Make Your Own Power Steering Lines TIPS Sources of Fittings for Power Steering Lines TIPS Loose steering column TIPS Dimmer Switch TIPS Replacing tie rods Tie rod dust boots Rubber bushing kit Tilt Steering column wobbling Removing air bag TurnOne Nothing on removing entire rack.`
1994 #353 "Bluey" |
02-28-2021 | #4 |
R&R of the rack is fairly straightforward with some pain in the a$$ aspects to it. Going from underneath after removing the tires and getting the front end in the air you remove the power steering cooler and the sway bar completely. Then disconnect the tie rod ends from the steering knuckles. The first tricky part is disconnecting the power steering hoses from the rack. It's a combination of access from the bottom and from the top. Be prepared to take your time and curse a lot. Next the mounting bolts for the rack have the bolts going in from the bottom with nuts on the top. Access to those nuts is also tricky, using a combination of long extensions and jointed sockets from the top on the passenger side and blind placement of box end wrenches underneath on the driver side. Once the bolts are out you slide the rack out from either side. Be sure to replace both the rack mounting bushings and tie rod ends with the rebuild. I count the number of turns each tie rod end is screwed on to the tie rod and note it. That way you can screw the new ones on the same number of turns be in the ballpark on the alignment toe in when it goes back together. Reassembly is in reverse with the same minor challenges.
Will you be rebuilding the rack yourself, sending it out for rebuilding (Turn One, excellent rebuilder but expensive) or will you get an exchange rebuilt rack? H
02-28-2021 | #5 | |
Im planning on sending the rack to TurnOne and springing for the expedited service depending on what lead time they quote me. I figured the sway bar would have to come out. Looking for fresh sway bar bushings but I only see 24mm bushings available and if I read correctly our bars are 26mm?
1994 #353 "Bluey" |
02-28-2021 | #6 | |
https://www.prothanesuspensionparts.com/71152 |
02-28-2021 | #7 | |
Now to wait 5-8 weeks lol
1994 #353 "Bluey" |
02-28-2021 | #8 |
Well the silver lining could be now is a good time to put the Z up on jack stands and get the rack out and to Turn One. Turn One?s site states 3 to 4 weeks until you get your rack back but I think when I had one done by them for another Vette, it took two weeks from them getting it to actually calling me to tell me it was done. Paying for the expedited service might get it done sooner but it could only end up taking a few weeks anyway. A bit of a dice roll.
02-28-2021 | #9 | |
Major suspension overhaul in progress, documenting it in my ownership thready
1994 #353 "Bluey" |
