05-14-2019 | #1 |
Full power key
One of the several things I had Marc H. do for me three years ago was to make the full power key work better. It worked a couple years but is now not working most of the time, so my question is can I simply by pass the switch? If so, how do I get the switch out to connect the wires together?
Jim 1990 Z # 2441 1959 c-1 230 HP 4 speed frost blue/silver 3 owner 2011 cts-v 556 HP, manual 6 speed 1955 chev 2dr ht PP 265 3 speed w/OD |
05-14-2019 | #2 |
Re: Full power key
You have to remove the console/radio trim to which the switch is mounted. Access is from behind. Bridging the wires only works on a 90’. 91 & up requires a modification to the chip.
H
05-15-2019 | #3 |
Re: Full power key
Thank you. Mine is a 90 and I’m going to pull the HVAC switches out to clean and will bipass the switch at that time.
05-15-2019 | #4 |
Re: Full power key
Good idea Jim while you are in there make a project out of it while you are there
08-11-2019 | #5 |
Re: Full power key
Anyone got a photo of the switches insides? What is getting worn?
Sometimes I've just gotta touch the key a bit to get "Full Power" back. Currently im also driving around without the radio trim, as I changed my mind halfway through a 2-Din stereo install. Didn't want to cut that much out of the plastic to enable fitment, so I'll rather fint a mech-less shallow unit. Don't need the cd-player. This also mean I'll have to attempt the switch by-pass, as my switch is still in the trim.
- '90 ZR-1 |
08-11-2019 | #6 |
Re: Full power key
Item #2........CMHSL LED, Full Power Key and Alternator Pulley
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-11-2019 at 03:31 PM. |
08-11-2019 | #7 |
Re: Full power key
I just finished cleaning my HVAC switiches on my 1990 and wired the key by bypassing the switch. Worked perfectly. The switch is easy to access and I broke apart the switch and the factory connectors nicely snapped together. I then taped them up and reassembled. Perfect fix to the “on and off” problem. My car was in Marc’s shop 5 years ago and he serviced the switch then which solved the problem for a couple years but the problem returned.
