Old 03-05-2012   #1
Blue Flame Restorations
Default VAC Leaks
Question????
Why doesn't anyone use compression fittings on the vac lines under the plenum? Either with plastic or even steel lines, in order to prevent un-needed plenum pulls????
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 03-06-2012   #2
Default Re: VAC Leaks
Originally Posted by Blue Flame Restorations View Post
Question????
Hummm.... That might work. I could be wrong, but I don't get the sense that it is a repeating issue. Once the rubber sleeves/tees are replaced - these 16-21 year old connections - that is that.
And, then there is the "sans secondaries" approach to the problem...
Parts not used seldom break, and they don't cost much to replace! & It runs so nice with that stuff "outta thar!"
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-06-2012   #3
I plan to remove the secondaries as well.
It just seems that I hear so much about vac leaks, I was just thinking "compression fittings". May not be needed??
Old 03-06-2012   #4
bdw18_123
When I rebuilt my vacuum system, I just replaced any cracked plastic hose and any hard or brittle rubber connections (the secondaries vacuum solenoid too). And I put small, black zip-ties on any rubber to plastic vacuum hose connection where the plastic side didn't have a little barb or raised area to help keep the rubber part on.
I've put over 3,000 miles on now since I got my Z running and my vacuum system is still nice and tight. One time after being in a store for 30 - 40 minutes or so, when I turned the key on, the pump only ran for a couple seconds and then shut off. And I do a lot of 'spirited' driving!
So I think that most of the vacuum leak issues are with the cars that haven't ever had the plenum off, or had the vacuum system gone through and checked out thoroughly. Those that have, I would venture to say probably haven't really had any more vacuum leak issues (if any).
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 03-06-2012   #5
John Boothby
John Boothby's Avatar
[QUOTE=So I think that most of the vacuum leak issues are with the cars that haven't ever had the plenum off, or had the vacuum system gone through and checked out thoroughly. Those that have, I would venture to say probably haven't really had any more vacuum leak issues (if any).[/QUOTE]
I agree. No problems since I replaced all the secondary stuff (with the exception of a new-out-of-the-box solonoid and a brand new actuator that went bad). I have reservations as to whether the car would pass smog with the secondaries removed.
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
John Boothby is offline   Reply With Quote
Old 03-07-2012   #6
I'm fairly new to the game but soak up everything I can. It just seems that we talk about vac leaks a lot.
Old 03-07-2012   #7
YES WE DO!
Following posts for some 4 years, & also having experienced a "little" of the "old ZR-1 Corvette" maladies myself, it occures to me that we should put together a DIY checklist for new ZR-1 owners.
Sounds like a topic for an article (hint-hint)
90 #1202
Sans secondaries
Old 03-07-2012   #8
RHanselman
RHanselman's Avatar
Brett,
I'd love to have a system that requires less maintenance... Great idea...
RHanselman is offline   Reply With Quote
Old 03-07-2012   #9
PhillipsLT5
PhillipsLT5's Avatar
Removed mine, less is better
Old 03-07-2012   #10
I am removing the secondaries on mine, so hopefully, I can avoid any hissing noises. LOL
