Old 01-12-2014   #1
Default 93-95 Cams; Anyone got a measurement??
Anyone got a set of 93-95 cams lying around? Wondering if you can measure the base circle; which should be 1.29-1.3; then measure the overall height. Found something funky on the ones I have
Old 01-12-2014   #2
Default Re: 93-95 Cams; Anyone got a measurement??
Lee,
Some measurements from some data samples I have made.
New 93~95 Cams, B/C: 1.299~1.304, O/A: 1.688~1.692
These dimensions are the same as 90~92 cams
A26B is online now   Reply With Quote
Old 01-12-2014   #3
hmmmm, mine are not....showing same base circle but more lift
Old 01-12-2014   #4
90-92 spare I have: I get .390
93-95
Primary Intake:
Secondary Intake:
Base circle: 93-95 ...same as 90-92
Old 01-12-2014   #5
Now these are the specs of a regrind...but regrinds have a base circle of 1.24-1.25
Old 01-12-2014   #6
and of course I have 2 right exhaust and 2 right intakes of these....
Old 01-13-2014   #7
Well, maybe they never were ground to stock lift. Entirely possible they were machined & ground from forged blanks with the stock B/C with higher lift.
There are quite a few of those around. I have 4 of them in my Zee.
SGC Stage I cams have 0.415" lift, close to what you are describing.
