12-21-2014 | #1 |
Plug for SW headers EGR port
Just received new set of coated Stainless Works headers. I have a '92 S/N 0172 and it doesn't have EGR thankfully! How do I plug this port on passenger side header? Seems like the way to do it would be to tap and plug it. Hate to sound ignorant, but can you tap stainless steel with a conventional tap? What size bolt or plug? High temp antiseize on threads?
Thanks! |
12-21-2014 | #2 | |
Re: Plug for SW headers EGR port
I am sure I also have a set of SW Headers from Stainless Works with that EGR port removed by SW.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-21-2014 at 12:51 PM. |
12-21-2014 | #3 |
Thank you, my friend. Found something at Advanced Auto called "QuikSteel". Could use as adhesive around a stainless bolt. Supposedly good to 2400 degrees.
01-23-2015 | #4 |
a 10mm 1.5 pitch bolt is a good choice. It was easy to tap by hand.
1990 #1471 Founding #006 Former Membership Director NCM member Grand Sport registry |
