11-07-2017 | #1 |
90’ Clutch Hydraulic Line
Is the 90’ clutch line unique to that year or can the 91’ and up line be used?
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. Last edited by Ccmano; 11-08-2017 at 09:53 AM. |
11-07-2017 | #2 | |
Re: 90’ Clutch Hydrolic Line
I am not positive. But I think they are the same. While I know of many unique MY 90isms. I have never heard that these are different. I'm sure WV knows for sure
11-07-2017 | #3 |
To my knowledge they are the same as non-ZR-1 applications. When you can find them (Corvette Mods, Ecklers and such currently sell reproductions) they are sold as 89-90 and 91-96. Steel tube bends look slightly different and the later one uses steel braided hose.
H
11-07-2017 | #4 | |
Reach out to the ZF.DOC I'm sure he knows
11-07-2017 | #5 |
Hans,
I just replaced the m/c and slave this spring = fresh in my memory! The hydraulic line for the 90 is solid bent steel sections on either end, separated with a rubber middle section. However, the 91+ line is rubber with a stainless braid. The 90 slave has the bleeder on the top of the slave, whereas the 91-95 is on the bottom. I recommend going with the 91+ slave AND the 91+ hydraulic line for ease of installation. Per Marc Haibeck's recommendation, I bought my m/c and slave from Rock Auto (cast iron as opposed to tube steel), and the hydraulic line from Corvette Central. I wrote an article detailing this in the last issue of HOTB, FYI. After it was published, I heard from someone with a later model (a '94 ZR-1) who pointed out that his car had a spring steel retainer clip on his m/c actuator rod, instead of a "C" (or "E"?) clip I mentioned in the article. (I'd be curious to know whether yours is a "C" clip or the spring steel type. (the spring steel I've seen on other stuff, and quite frankly would be preferable to the "C" clip, IMO.) Cheers!
11-07-2017 | #6 | |
Good to know thanks Paul
11-07-2017 | #7 | |
Best Hans
11-07-2017 | #8 |
Paul, just reread your article in HOTB. Went ahead and ordered the whole she-bang. Mytivac included!
H
11-08-2017 | #9 | |
Very handy tool (Mytivac reservoir). And, a set of Russell 639630 Speed Bleeders placed in your calipers used in conjunction with that Mytivac reservoir and a vacuum bleeder pump and clear plastic tubing makes brake bleeding a simple, one-person job done very efficiently! FWIW! P.
11-08-2017 | #10 | |
H
