Old 07-22-2015   #1
cvette98pacecar
Default Borescope for Android.
Here you go, a borescope for your android phone or tablet.
http://www.banggood.com/Mini-Android...&utm_design=14
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 07-22-2015   #2
Racinfan83
Default Re: Borescope for Android.
That's actually pretty cool. Would like to hear from someone who has one how good it is before buying though...
[LEFT][SIGPIC][/SIGPIC][/LEFT]
[CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER]
Old 07-23-2015   #3
Hey! Good to know there's movement toward a reasonably priced scope. 7mm eliminates most of my competition stuff (5.56 and 6 mm), but should work on the "30s"!
And, I imagine this would be a solution to inspecting the chambers of our LT5s as well?? Worth exploring, methinks!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-23-2015   #4
I tried using this unit connected to a laptop with Windows 8. I had no luck with it . The problem was a software glitch with M/S 8.I used it on a older laptop with Windows XP and it worked fine. The borescope showd the piston top & cylinder walls very good on the bright setting. The borescope could find some of the valves but not well. And couldn't view the cylinder head from the spark plug hole. We didn't send the borescope down the intake to view oil and carbon buildup in there. Maybe in the future.
There are no secondaries in this engine that could stop the scope from getting all the way to the intake valve.
Bear in mind that this is a very inexpensive borescope. For the price the scope is worth it IMO. Seeing under the plenum etc. can also be a huge reward.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
