Old 12-10-2016   #1
ALLTHECAMS
ALLTHECAMS's Avatar
Default Winter storage
I've always stored my cars with a full tank, but one of the guys in my Corvette Club says to store a C4 for the winter with less than a 1/4 tank because a couple of sensors in the tank can go bad. Is this true? Also, does anyone use fuel stabilizer like Sta-bil?
Thanks
Matt
1991 ZR-1 #520 Arctic White/Gray
ALLTHECAMS is offline   Reply With Quote
Old 12-11-2016   #2
Default Re: Winter storage
I would recommend storing with a full tank treated with Sta-bil.
Old 12-11-2016   #3
ALLTHECAMS
ALLTHECAMS's Avatar
That's what I thought. Thanks.
Old 12-11-2016   #4
efnfast
I store my car full with a stabilizer from Amsoil.
Old 12-11-2016   #5
BigJohn
BigJohn's Avatar
Yeah, someone has to help the Amway Boys keep their 200 foot yacht open running!
Old 12-11-2016   #6
on the full tank. Condensation is a REAL concern in winter.
However, my small engine mechanic steered me to Sea Foam, stating issues with (other stabilizer(s)).
I had the issues he was talking about with some small motors. But, someone had advised me to run a "stabilizer" additive and then run the tank dry before storing. As result, the jets got plugged on 3 different engines.
So! I don't know if the difference was having a full tank or not, but a full tank and SEA FOAM have yet to fail in over 15 years of winter storage of 9 engines.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 12-11-2016   #7
Roadster
Roadster's Avatar
I know everyone has their own ways of storing their vehicles. I do agree with a full tank of fuel to avoid condensation during storage. But I guess what I don't understand is why people store their vehicles away for months and never start them at all.
Here in the Metro Philly area, it can get quite cold. But even though I wouldn't use the Z that much in the winter when I was still working, I would always start the engine at least once every 2 weeks. Back out of the garage and let warm up to operating temps and either drive around the block a few times or go for a 5 to 10 mile trip, depending of course on weather conditions. That way I am burning off any condensation build up and still get the pleasure of going for a ride. It would be real hard for me to have the Z or any other vehicle covered up and not used during the winter months in nice weather conditions.....
To those that do store, this is not a criticism of what you do, but JMO....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 12-11-2016   #8
efnfast
I usually pick 2 or 3 nice days during the winter and back her out of the garage, I let it warm up, but can't take it for a drive.
Old 12-11-2016   #9
For both Corvettes and snow blower, I have never needed a fuel stabilizer here in Chicago. Maybe just lucky but all I do is fill the tanks. I check that the oil is also full, put the Corvette on a battery tender and increase tire inflation pressure to 40 pounds or so to minimize flat spotting. I used to run the tire pressure to 60 psi per a friend who stores (and restores) lots of classic cars but techs at Costco told me that valves were only warranted to 40 psi. I found that out when I developed a slow leak that turned out to be a defective valve (which they still kindly replaced for free). Probably could go 50 psi but I am sticking around 40 for now. Historically I never had a big problem with flat spotting using increased pressures for storage. I normally take insurance down to Comprehensive only so I don't drive them for roughly four months. A sad thought, but I am cheered by the fact that we have only ten more days until the days start getting longer --Bob
Old 12-11-2016   #10
Mystic ZR-1
Mystic ZR-1's Avatar
A cold start is the WORST condition for any engine.
Why do it every couple of weeks for 5 - 6 months?
Once in the Spring is fine. Minimizes wear.
A little over kill... but I put an electric space heater under
the car for several hours (car on jack stands) to warm things
up, it's called pre-heat in the aviation world, before starting in the Spring.
Oil pressure comes right up. During this drill, the running gear gets exercised too (with no load), even in neutral everything is turning.
Full tank with Stabil for storage, new oil and filter (run till warmed up) when putting to bed for "a long Winter's sleep".
Kleenex for the tears of withdrawl...
Mid April's just around the corner...
OBTW: A battery tender too.
