If you have a very cold concrete floor you may get condensation from warm air passing over the cold floor which collects on the underside of the ZR-1. These interlocking 2 ft x 2 ft closed cell EVA 3/8 inch thick foam pads are ideal to add a bit of a moisture barrier between the floor and underside of the ZR1 as well as nice anti slip when working on the LT5 or getting in and out of the ZR-1.
![]() Ebay Showroom Flooring in your own garage/shed You select color and total coverage in square feet. mats are packaged in packs of 24 SQ FT - There are 6 tiles and 10 border pieces per pack - Each tile measures 24" x 24" and is 3/8" thick (10mm) - Each tile weighs ~ 1 pound - The material is closed cell EVA foam I selected 168 square feet or 42 2 ft x 2 ft Black mats. I also selected 168 square feet or 42 2 ft x 2 ft Red mats. One complete mat is 10 squares x 4 squares. The other complete mat is 11 squares x 4 squares.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-27-2015 at 12:09 PM. |
![]() Join Date: Nov 2014
Where would you pick up those pads?
![]() ![]() Join Date: Nov 2007
Quite nice, there Cliff! Mid America (or the like)?
Worth every cent - especially if you get them (or something like 'em for nuttin'! I used to have terrible condensation issues until I laid down some carpeting pieces I got from a carpet store (free!), each big enough to cover the shadow of the Zs. That ended the condensation issues completely. ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-24-2015 at 10:18 PM. |
