Old 11-10-2017   #1
MuRCieLaGo
Default Hunting idle issue
Hello guys,
Today is a good day. Been searching for a long time for my low RPM bucking issues (especially when warm).
Changed o2 sensors, fuel filter, fuel pumps, spark plugs, spark plug wires, cam sensor, battery... All without success.
Today, I changed the coil packs. It seems to have fixed the problem. The car was running fine at high RPM, I still don't understand!
Anyway, it brought a new problem. I've got slightly high and hunting idle now. As you can see in the video, nobody touched the gas pedal on throttle cable and it went all the way from 800 RPM to 1,900 RPM all of a sudden.
https://www.youtube.com/watch?v=Jr7QD11eJzs
I've got no clue what it could be.
Any ideas?
Thanks!
MuRCieLaGo is offline   Reply With Quote
Old 11-10-2017   #2
Ccmano
Ccmano's Avatar
Default Re: Hunting idle issue
A hunting idle is almost always a vacuum leak. No magic bullet for that. Just a matter of going through and checking and eliminating the various vacuum systems.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 11-10-2017   #3
Billy Mild
Vacuum leak. Make sure everything is ZIPtied or RTV'd to seal up any leaks. Outside of that if that all checks out then place a book in front of the airhorn. If the idle drops down then that is your issue. The TB sticks.
On the point of getting the Vacuum leaks fixed make sure to use a mityvac on each connection with the manifold on to see where its leaking at. The MityVac really helps pinpoint this stuff.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 11-10-2017   #4
Vacuum leak X3
Old 11-10-2017   #5
When you swapped coil packs, did you disconnect throttle cable when removing plenum?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-10-2017   #6
MuRCieLaGo
Vaccuum leak - I'll double check...
But personally I think XfireZ51 is closer to finding the problem.
When I disconnected both cables, I heard a weird sound from the system - like if I broke something... Couldn't see anything obvious though.
In the video, you can see that it went from 800 RPM to 1,900 RPM pretty fast. A raise to RPM due to vaccuum leak would be much slower, no?
By the way, thanks a lot for your help guys. I bought a Viper 1994 and the forums are pretty bad. People are being sarcastic and think they own a Ferrari. I love this forum here.
Old 11-10-2017   #7
MuRCieLaGo
I just started it at a pretty cold weather and I had a rock solid idle at 1,500RPM...
Old 11-10-2017   #8
Ccmano
Ccmano's Avatar
What year is the car?
H
Old 11-10-2017   #9
MuRCieLaGo
1991
Old 11-10-2017   #10
Ccmano
Ccmano's Avatar
So we can count out the ASR adjuster cable, 90’s and 91’s didn’t have ASR. Check the throttle and cruise control cables, there should not be any tension on them at idle. Just a very small (tiny) amount of slack.
Make sure there is nothing interfering with the throttle linkage assembly to hold it slightly open. That assembly where the throttle cables hook into.
If you find that the throttle linkage is fully at rest when idling we have to look elsewhere.
The IAC motor is another possibility. It was no doubt disconnected when the plenum was off. Try resetting it. #4 post in the following thread.
http://www.zr1.net/forum/showthread....ight=IAC+reset
I still strongly suspect a vacuum leak somewhere.
H
