04-05-2010 | #1 |
92 ZR-1 in Knoxville for $15k
80k miles, just getting warmed up.
http://www.carsetc.com/used/Chevrole...03ab3c3672.htm Who needs a family car when you could daily drive a ZR-1? |
04-05-2010 | #2 |
Re: 92 ZR-1 in Knoxville for $15k
Good price from first glance for sure
Bigun 1990 ZR-1 #618 Black/Gray (sold) NCRS, ZR-1 & NCM member |
04-05-2010 | #3 |
Fishy!!!!!!!!!! All the cam cover bolts apear to be rusty as do the inner fender bolts. It also looks like someone has relocated the temp sensor to the back of the passenger side coolant pipe.
04-05-2010 | #4 | |
And why do you have a "LT4" under your name? You have an LT5 right? Same for me....and can't change the LT4 info.
04-05-2010 | #5 |
The LT1/LT4 etc. is determined by the number of posts you've made. Make enough and you move up in 'class'.
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
04-05-2010 | #6 |
someone has played with this car, Id be less worried about some corrosion on bolts. It happens my cars were close to the ocean and I got rust on hardware.
Not like that ebay car but hardware corrodes first. It does have those silly plug wires on it so they are grounded to the plenum someone has had it apart, and for 80K miles those pics the cars paint looks great and the interior isnt bad. AS for you two being LT4s you need to post more thats all that is is basedon your post count.
