02-06-2013 | #1 |
2 Bolt vs 4 bolt Main Caps and Nitrided Stock Crank ... strong? ---
I just realized that the crank was a Nitrided crank , and that the early lt5 engines used 2 bolt main bearing caps vs 4 bolt in the newer engines.
Is there any known failures from the 2 bolt engines that are more common than with the 4 bolt engines? Is the crank Cast or Forged , then nitrided? Whats the consensus on how many HP our bottom ends can handle? I just picked up THE HEART OF THE BEAST ... figured I should start reading up on our cars , this is where I got this engine info from (stuff posted on the net from the book). Thanks ---
[SIGPIC][/SIGPIC] 01' Dodge Viper GTS 11' Ford Raptor 90' ZR-1 Corvette LPE #699 |
02-06-2013 | #2 |
Re: 2 Bolt vs 4 bolt Main Caps and Nitrided Stock Crank ... strong? ---
2 bolt vs 4 bolt makes no difference.
02-06-2013 | #3 |
the LT5 is a "ladder bar" split block design and the 2 bolt blocks are plenty strong. the crank is a very stout forged casting
although the 4 bolt design is "marginally" stronger, (about 5%) the 2 bolt block set the endurance record and is plenty stout when you look at the new LS motors they went to a deep skirt cross bolted design which is cheaper to manufacture. you can't really compare a "2 bolt vs 4 bolt main" design with separate main caps holding the crank with a traditional chevy block the ladder bar bottom case holds all the caps in a very rigid structure on the LT5
02-06-2013 | #4 |
i need to read up on the bottom end of the lt5. never really bothered before, not sure why
02-06-2013 | #5 |
Is the Ladder Bar Bottom sorta like using a "block girdle" ?
Thanks for that explanation ---
02-06-2013 | #6 |
I will explain it this way.
two 1/2" inch bolts or four 1/4" inch bolts They went with smaller bolts on the 4 bolt blocks Let me add, some might say your spreading the load with smaller 4 bolts but the ladder frames have so many screws all the way around i don't think 2 more smaller screws will make such a big difference to handle that much more power. So if your building a 1000hp motor and the 4 bolt can handle another 25 or 50hp more at that point who cares. To me makes no difference. Some of the fast FBI Z's are 2 bolt blocks making 650-700hp Stock crank is forged. We know stock bottom ends can handle 600hp i think they could handle 800+hp. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 02-06-2013 at 10:03 PM. |
02-06-2013 | #7 |
Awesome, Thanks Pete ---
02-06-2013 | #8 |
If I recall correctly the 4-bolt "enhancement" was a sop to GM after the supposed crank failure "issue" that was actually caused by an improper starting procedure during testing. Lotus didn't believe it was necessary.
Dave
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
02-07-2013 | #9 |
My 2 bolt stock crank and rods endure over 700 chp and 660 tq.
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
02-07-2013 | #10 |
Something else...
The bolts sandwich the block between a ladder "girdle", into which the main caps are moulded, and the heads. The bolts of the 2-bolt motors are MASSIVE, and weigh over 21# alone! To think of the LT5 2-bolt vs. 4-bolt from the perspective of a SBC (or even a BBC for that matter), is totally wrong. It is an entirely different animal - top to bottom. Looking at it dissassembled, it is one beefy mutha! Standing around over brewskies with Dave Mclellan at a JVD BBQ during one of the recent Bowling Green GTGs, Dave said the LT5 (bottom end) "...should be good for 1000 hp or a little more." FWIW, P. P.
