Old 06-24-2009   #81
bobbyhi
bobbyhi's Avatar
Default Re: Cam Cover Emblems
If there is a failure at those temps then I would lower the temps to 300 degrees max and re-test. Shouldn't need more than a "cushion" of 50 degrees. I shot my temp gun last weekend of 90 degree weather and the covers were 205 degrees.
Old 06-24-2009   #82
flyin ryan
flyin ryan's Avatar
Wink Re: Cam Cover Emblems
300ºF should be 'Lots'.
Old 06-24-2009   #83
Jagdpanzer
Jagdpanzer's Avatar
I would not expect these emblems to see more than 225º F even in the higher temp climates.
Old 06-24-2009   #84
bobbyhi
bobbyhi's Avatar
I would suspect that you are correct - however, there should be some "fudge" factor built in to the max temp range.
Old 06-25-2009   #85
flyin ryan
flyin ryan's Avatar
Not a lot of air movement under the hood of these things...I could realisticlly see more than 225ºF quite easily, under the right or more correctly 'Wrong' conditions.
Old 07-03-2009   #86
How is this:
Curve:
Old 07-03-2009   #87
Those look AWESOME
Old 07-03-2009   #88
limey
I think you have a winner!
Put me down for 30 sets!
limey is offline   Reply With Quote
Old 07-03-2009   #89
carter200
carter200's Avatar
The circle looks thicker. All else looks great.
Old 07-03-2009   #90
6 test versions are coming to me, they offered to make the cirlce thinner....I will see how the current version works....also we will get stared on 91-95 version.
