Old 02-11-2020   #81
Tripler
Tripler's Avatar
Default Re: Ruff Idle ,Huge Loss of Power
Found the one I have
Attachment 11218
Thankyou very much . Got it yesterday . Now just need some warmer weather to install it .
Tripler is offline   Reply With Quote
Old 07-11-2020   #82
Tripler
Tripler's Avatar
Attachment 11218
Installed the float a few weeks ago . Checked it yesterday and it works perfectly . Fuel is now showing full, not 3/4 like it used too when the tank was actually full .
Thanks
Mike
Sent from my SM-A205W using Tapatalk
Old 07-14-2020   #83
Tripler
Tripler's Avatar
Got the car up and running with new Summit Racing Injectors . Running smoother but still ruff idle . Smooths out exactly at 2000 rpm . Should it not now idle correctly with new injectors ? I have done the battery disconnect twice now to reset ECM .
What is the next step I should be looking at ?
Be doing a test drive today .
Will post later how it went .
Old 07-14-2020   #84
Which injectors are u using? Is there a number?
Old 07-14-2020   #85
Tripler
Tripler's Avatar
ACC- 150821
Car is the same . Test drive went badly .
Old 07-14-2020   #86
Tripler
Tripler's Avatar
Accel
Old 07-14-2020   #87
Ccmano
What year is your car? 93 or later? I noticed the EGR hose on an earlier photo you posted. If so have you checked the EGR valve and it?s control circuit? An EGR valve that is hanging open will cause these types of issues. Refer to your FSM for testing.
H
Old 07-14-2020   #88
Yes ok. Accels. That?s what I thought. Any chance u checked coils and wires before putting plenum back on.
P.S. Just a hint. Always order multiple sets of plenum gasket sets from Jerry. 🤣🤣
Old 07-14-2020   #89
Tripler
Tripler's Avatar
1995 . No , I did not check the coils . How would I check the coils .
Thanks
Yes , ordering 2 new gasket sets .
Also another has popped up . No AC now . Yikes
Mike
Old 07-14-2020   #90
Ccmano
Thanks
Mike
Check the EGR first...
H
