Old 05-04-2018   #81
Default Improved Fuel Pressure Regulator
Just completed installation of the IFPR on a 1990 ZR-1 #3032 and 1990 ZR-1 #2067.
The Performance is identical to the IFPR in the 1990 ZR-1 #72 and the 1995 ZR-1 #186.
(I have installed four Improved Fuel Pressure Regulators all of which perform perfectly).
When you are installing the Improved Fuel Pressure Regulator, also install the New Secondary Port Throttle Vacuum System for zero vacuum leaks and the Rebuilt 124 Amp O'Reilly's Alternator.
Post 283 - Phil's (Jagdpanzer) Fuel Pressure Regulator Solution
Post 284 - New Secondary Port Throttle Vacuum System
Post 285 - Alternators
Old 05-05-2018   #82
Default Re: Potential Fuel Pressure Regulator Solution
how do we procure one?
Old 05-05-2018   #83
Jagdpanzer
Jagdpanzer's Avatar
Jeff,
I will be glad to do one for you however, I will need your core as I do not have any extras myself. $165 covers a new Delphi FP10016 regulator, machine work, necessary seals, hardware and assembly. Return shipping and insurance runs around $15. Turnaround time is 2 to 3 days provided family or work obligations don't get in the way.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-05-2018   #84
Phil, that sounds great, however, I will have wait until fall, it is now driving season, I want to enjoy the car for the summer
Old 05-05-2018   #85
5ABI VT
Got my gaskets and o rings from Jerry just a few days ago. I’m hoping to have mine out and on the way very soon !
Old 05-11-2018   #86
RichS
I sent Phil a spare regulator to have done, I put it on a week ago and drove it once to check it out. Pressures are right where they should be, I found a broken u-joint on a 1/2 shaft so I need to swap that out before taking it out for a long ride. I think I've had the upper off a few too many times, took less than a hour to swap out. Thanks again Phil!
RichS is offline   Reply With Quote
Old 05-11-2018   #87
Top Toy
Top Toy's Avatar
[QUOTE=RichS;279028]I sent Phil a spare regulator to have done, I put it on a week ago and drove it once to check it out. Pressures are right where they should be, I found a broken u-joint on a 1/2 shaft so I need to swap that out before taking it out for a long ride. I think I've had the upper off a few too many times, took less than a hour to swap out. Thanks again Phil![/QUOTE
Rich - you're just going to have to cut back on those full throttle launches!😉
'95 ZR-1, aqua/gray, #167
368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP.
Top Toy is offline   Reply With Quote
Old 05-12-2018   #88
One more ZR-1 with the Improved Fuel Pressure Regulator Installed. I also install new Secondary vacuum systems when I am under Plenum for ZERO vacuum leaks...Vacuum pump fires up when switch on and just does not come on again for a long long while
Old 07-13-2018   #89
5ABI VT
Thought I’d share here a few pics I put on my Instagram. Big thanks to Phil the regulator looks awesome and turnaround time was super fast even being in Canada 🇨🇦.
Pics of my old internals
Can see obvious signs of aging but who knows if and when it may have failed or started to affect function. Peace of mind that it’s brand new now
Old 07-15-2018   #90
Lots of posts here about injector failure...…...as I also found out we now know part of the reason as that fuel from the Fuel Pressure Regulator is not filtered (those rust particles have to go somewhere and I doubt most can pass through the injectors)
I have replaced ALL Fuel Pressure Regulators with the Phil Modified Fuel Pressure Regulator and if the injectors have not failed yet, they will now last a very long time.
Post 281 - The Improved LT5 Fuel Pressure Regulator
