Old 07-10-2015   #81
5ABI VT
Default Re: LT5 Cooling and Radiators
Sooo.. which rad do you guys recommend? Im debating on pulling mine for cleaning and a lower temp tstat but an upgrade is in my thoughts.
Old 07-10-2015   #82
RussMcB
I'm in the same situation (after very high temps while doing laps at race tracks) and after two discussions with Marc I've decided to clean my current rad first to see if that helps (and try to keep the RPMs down next time at the track). If I still think I need a better rad, and I have plenty of $$$ in the checking account, I'll go with a Dewitts. I do think there are several other very good choices, too, like Ron Davis. If saving money is important, Ron Davis offers a generic Chevy NASCAR model that will work with some mods.
Those are my conclusions after discussions and searching. No real world experience.
Old 07-10-2015   #83
I suggest Dewitt's and add the SPAL fans. Install is easy and you will gain a little more clearance as the back of the radiator shroud is removed and the SPALs mate to the back side of the front Rad shroud
Old 07-11-2015   #84
dredgeguy
dredgeguy's Avatar
After seeing the debris in my stock 92, cleaning was out. Would have to send it out and then you still have a 23 year old radiator with plastic sections. Looked at options and costs and went with a DeWitts, a new 180 degree Stant and new hoses from Jerry's.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 07-11-2015   #85
lbszr
lbszr's Avatar
My stock radiator would climb at the racetrack, caught it at 250 or so and had to short shift on a 85 degree day.
Today in bowling green track, 30 minute sessions, 95 degrees, it stops at 212, but I did see 216 max. DeWitt, also a big mouth. Had the big mouth on the stock rad, but wasn't enough. I also have manual switch to turn the fans on, I leave it on all the time during track use and it makes a difference.
Oil temp stays steady at 250. Hair below the caution bars.
I think the radiators all mentioned are plenty good.
Old 07-19-2015   #86
5ABI VT
Just curious if there are any write ups for the install ? In debating on pulling the rad out and cleaning it out before a runway event I signed up for in a few weeks
Old 07-19-2015   #87
There is a write up on corvette forum that should cover most of the job
Old 07-19-2015   #88
RussMcB
I'm in the middle, early stages of an R&R. I've removed the stock radiator. It was a bit more difficult than expected. There are three 7mm screws on each side connecting the upper shroud to lower - very hard to access. When I put it back together I'll reverse them and install from the inside for easier access (I read that suggestion in other discussions).
Not surprisingly, there was a lot of dirt and junk in there. I could probably clean and reinstall the stock radiator, but I'd rather not do this job again, so I'm ordering a Dewitts.
As with most of these projects, it's growing. I ordered a set of hoses and a t-stat from Jerry's Gaskets, a "Big Mouth" air dam*, and I'll be adding a screen to help keep out leaves and junk.
To answer your question, I do think you could do the job in a day or weekend (or two nights). If it has never been out and cleaned, I'd think it will be very worthwhile before your track event.
* http://www.c4orcecorvette.com/
Old 07-19-2015   #89
5ABI VT
Just saw the write up and its a good one . My concern is the oil cooler. Does that have any effect on the re/re procedure? More than likely Ill be doing an upgraded rad in the near future but Im sure this one will be full of crud. 21 years old and possibly never out. A few weeks ago with the ac on and parked I noticed the temps did seem to rise quite a bit. I never sit in traffic but when moving they came down pretty fast.
Old 07-19-2015   #90
RussMcB
The oil cooler stays in place (but you will need to disconnect the lines - just one bolt).
With the radiator out you can blow out the oil cooler's and A/C fins.
It's encouraging that your temps come down pretty fast when the car is moving.
When you go to the race, keep in mind that the coolant in the water pump begins to cavitate at high RPMs, so you can short shift to avoid that if needed.
