#81 |
![]() Join Date: Feb 2009
Sweet! Booked!! Thanks David!
Rich
#82 |
![]() Join Date: Jan 2004
No but I might have accidentally found another pic of Frank (FU).
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 |
#83 |
Which hotel is this at ? For this first timers?
I am also interested in the tour
#84 |
#85 |
Thanks David
#86 | |
![]() Join Date: Sep 2012
Thanks, Prez (Congrats, BTW). It's working fine now.
#87 |
![]() Join Date: Aug 2012
Just signed up using my Holiday Inn points, 20,000 per night. Looking forward to it.
#88 |
![]() Join Date: Feb 2013
I made reservations for The Gathering at the 20 NCM event last august at the Country Hearth Inn that is across the street from the NCM. Is anyone staying there? Seems like an ideal location especially for 50 bucks per night!
Jim 1990 Z # 2441 1959 c-1 230 HP 4 speed frost blue/silver 3 owner 2011 cts-v 556 HP, manual 6 speed 1955 chev 2dr ht PP 265 3 speed w/OD |
#89 |
![]() Join Date: Feb 2006
I've stayed there in the past - it's pretty basic - you get what you pay for. Wifey likes it because she can walk from the NCM when she gets bored with guy stuff.
#90 | |
I have seen it and it's pretty rough. You get what you pay for, like Glen said The holiday inn is renovated, hot buffet breakfast for 2pp (thanks Robert) and center for all nighttime activities after the NCM closes Can't wait for 2015!! Cheers David |
