Old 12-02-2013   #81
Default Re: wheel refinishing?
Yes, that would be preferred
Old 12-02-2013   #82
WVZR-1
bolt on Right says "R O" and "TITAN"
both are M6 as far as I can tell, one is about 28-29mm the other 32mm
Found some chrome plated ones on eBay for $60 per wheel r $220 for all 4. I doubt I can get these parts from Speedline, not sure where else to look
They appear to have different shoulder dimensions but of course that could be maybe a "visual" thing from the snapshot. You need to confirm which is correct - I assumed the 120 count because they were the majority but maybe that's wrong. What was the hex size of the nuts? M6 I believe would be M10 and M7 would be M11. I don't know that you could rely on those but I believe anything else would be a specialty dimension. The heads of the bolts appear to be different also, 6pt vs. 12pt, yes/no? Were the nuts also 12pt? You didn't mention. I believe you need to look seriously at M7 hardware.
M7 Titan here:
http://www.enha.eu/product_info.php/...32-titan.html/
Almost every M7 spec is displayed here and you could dimensionally match the flange diameter etc:
http://www.titanium-touch.de/shop/in...--nbsp-M7.html
A simple vernier answers most of your questions, M6 thread diameter would be less than 6mm and M7 would be 6mm +. Both are 1.0 pitch so the screw pitch gage is of no value. What's the bore dimension of the holes? Not the painted centers.
Old 12-02-2013   #83
You are right, these are M7.. Caliper shows just over 6mm on the diameter, head is 8mm 120 are 12pt and 40 are 6 point. I will check the barrel hole size tonight,
Now that I think about it, the but is 11mm also 12pt
Old 12-02-2013   #84
Another interesting thing..
many I find that are M7x32mm are chrome.. I was thinking Stainless would be good but
the Chrome are tensile strength of 12.9 while Stainless is 10.9
would 10.9 be okay?
Old 12-02-2013   #85
WVZR-1
I would think you would want to avoid the chrome and 10.9 is fine. The other thing to consider is the torque of these. Some/most I believe settle on a spec that is 17 - 20 lbft. When/if you see values greater than those I'd be somewhat skeptical.
Since time is maybe not an issue why not just post a WTB in the tire/wheels, autocross/road-racing sections of the CF with specs and a "snapshot". Someone may just have a couple handfuls of the "Titan" product you need for a match OR maybe knows "where to get"!
You should have enough information I'd think to do the WTB>
Old 12-02-2013   #86
well I found a set of Stainless for a good price, I might just go that route, but I will do a WTB on CF and see if anything happens..
Old 12-02-2013   #87
would 10.9 be okay?
Id go with stainless due to pitting rust concerns in your neck of the woods. GC
Old 12-02-2013   #88
how do I tell if the original bolts were titanium or Stainless?
Next is to verify the flange size, some are 14.9 others are 12.9
I found a set of Stainless with the 12.9 flange, but need to measure mine at home
Old 12-02-2013   #89
Gotta be stainless.. titanium would have cost a boat load still does to this day
Old 12-02-2013   #90
so If I go stainless I could just do one wheel to match it or get all new bolts nuts..
