12-14-2013 | #81 |
Re: 1990 Throttle hesistation
12-14-2013 | #82 |
THanks there Dom...
But I'll tell ya'; it's @ the point where if I take the long way around, I might find something that's @ the root cause of this issue. And then again, I might NOT ever find anything...
12-14-2013 | #83 |
I can't tell from the video but does the stumbling continue or only just after you move the throttle?
12-14-2013 | #84 |
Chuck, Your secondary injectors shouldn't cause a hesitation just off idle but it won't hurt to check (ohm) them anyway.
After watching that video again it appears to me that the ECM may be fuel mixture hunting just off idle - not so much of a hesitation. Could it be the O2's or ??? Last edited by Franke; 12-14-2013 at 11:00 PM. |
12-14-2013 | #85 | ||
Above 2.4% about, it's fine all the way up... I'm not even planning ohming the 2' INJ's
12-15-2013 | #86 | |
And it's just as before, except 0% idle is perfectly stable now.
12-15-2013 | #87 |
Franke, Dominic - I'm about 99% certain that my answer is in posts 37, 38, and 39, on page 4 of this thread.
I don't remember at the moment how I got this DM data - help? And can I get this data in a lined DM graph?
12-16-2013 | #88 |
Some more testing here.
TPS baseline (motor off): .53V; 0% TO in DM Screwed in TB stop screw .55V; still 0% TO Screwed in to .57V; TO still @ 0% .59V; still 0% TO TPS bouncing from .59V - .61V; TO% bouncing from 0% - .4% THIS IS .06 - .08 INCREASE, BEFORE TO% SHOWS OPENING. NO MANIFESTATIONS OF A PROBLEM ARE APPARENT AT THIS POINT, WHEN RUNNING. .61V steady; .4% TO steady .61V - .63V TPS = .4% - 1.2% TO .63V = 1.2% TO steady both ends .63 - .64; 1.2 - 1.6% TO .64V TPS = 1.6% TO; steady both ends. This is where the idle swing begins, usually about 100 RPM's. .64V - .66V; still steady 1.6% TO SLIGHT more turn gives .64V - .66V; TO% bouncing from 1.6% - 2.4%. This is where more pronounced idle swing starts - about 350 RPM's. .66V steady; 2.4% TO steady. .66V - .68V; 2.4 - 2.7% TO .68V steady; 2.7% TO steady. She won't hold 2.7% TO while running. .68V - .7V; 2.7% - 3.1% TO .7V steady; 3.1% TO steady .7 - .72V; 3.1 - 3.9% TO And the throttle stop screw is pegged. Not to worry; another @ hand 1/4" longer...
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 12-16-2013 at 05:21 PM. |
12-16-2013 | #89 |
OK lets throw in a ringer. in a lt-5 the spark and fuel is controlled by the dis module until about 400 rpm where it is passed to the ecm. I once had a dis module that was fine until about 400 rpm then it fell apart. Took me 2 years to find out that they make a dis checker. As soon as I used it I could see it falling apart on a handheld scope and I replaced the dis module.
Tyler
55 Polo White (Project) 61 Jewel Blue (Sold to buy above) 66 Nassau Blue 68 Torch Red 88 ZR1 Blue 90 ZR1 White |
12-16-2013 | #90 |
Not sure if you changed out that TPS or not but it seems like it happens at the same tps position each time. Your thoughts?
